LOST WIFI SECURITY KEY WORD
If you have lost your WEP/WAP wifi key phrase there is no way to recover it except go into the router administration settings and see if it is in plain text there. If not then you will have to make up a new key phase and apply it to ALL your connected devices.
In future, write the key phrase down on a piece of tape and apply it to the bottom of your router. You can use a hint instead of the actual phrase.
I use the memo function of my cell phone to keep all my passwords and keys.
If you do not have any wireless network security enabled on the router,
your neighbor can see this SSID and connect to the network without
authorization. While this is generally frowned upon as being unethical,
it is technically not illegal as you have "made the network available"
by failing to secure it. The easiest way to secure the network is
through the use of a WEP key or a WPA pass-phrase. WEP keys are
generally 5, 10, 13 or 26 randomly generated characters long. WPA
pass-phrases are just that - a phrase such as "The sun is yellow".
Either method will prevent unauthorized users from accessing your
network. Only those individuals who possess the key or pass-phrase are
granted access.
These options is located under the Wireless > Wireless Security tabs from within the router administration.After login you can change the password.
If you need any kind of technical assistance you can contact support cell at here
Try the following procedure on a computer that's directly connected to one of the router ports with an ethernet cable. This procedure will not work if you're connected wirelessly. Open a web browser, such as Internet Explorer, and type in http:192.168.1.1. A window should pop up asking for a user name and a password. Don't enter a user name and type admin for the password. Hit ok. The router setup screen should come up. Click on the Wireless tab and then the Wireless Security sub-tab. You should be able to see your present wireless network security key on this screen. You can also use this screen to change the key if you want.
If you want to make some changes first select the security mode you want to use. I believe WPA gives better security but I've had some trouble using it on older computers. I use WEP. I've been able to get this encryption scheme to work with all of my computers. Next select the type of encryption. I like 128 bit 26 hex digits. Next enter a pass phrase and hit generate. The pass phrase is like a password. It should now generate four 26 character keys made up of various letters and numbers. Write down the first key and make sure you've checked the 1 box for default transmit key. Save your setting and exit. You wireless network is now secure. If you try to connect to it using a wireless device you will be prompted for a security key. Depending on the operating system you're running, you may just be able to enter the pass phrase or you may need to enter the 26 character key you wrote down. You should only have to do this once for each of your wireless devices. After the first time they connect to the secured network they should automatically remember the security code. I hope this advice helps you out.
If you're using WPA or WPA2, the password will be a key, so to make it a word or phrase, switch to WEP (which isn't as secure). You can do this by going to the Wireless Security section, under the Wireless tab, and choosing WEP for the Security Mode, then input the word or phrase you want to use. (You'll also have to update all of the devices that connect to this router so that they can still have access.)
WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
WPA pass phrase is a password for the wireless network to make it secured. You can obtain the WPA pass phrase when you access your router. Check the manual of your router for the address, username and password of your router. Go to wireless settings, you will see ther the SSID or Network Name, Network Key or the Pass Phrase and Authentication (WPA/WPA2/WEP). You can personalize the SSID,Network Key and Authentication. Remeber that for you to connect wirelessly the Authentication and Network Key on the router should match the Network Key and Authentication of the Printer or Computer.
I am assuming by access key your are referring to the pass phrase. The easiest way to approach this would be to use a cable to connect directly to the router from your laptop and confirm the wireless configuration on the router. You may have the pass phrase correct by the router is using WEP and your laptop is set to WPA or visa versa. Confirm the wireless configuration on the router then unplug the laptop from the router and change the configuration for you wireless settings on the laptop.
Are you talking about your wireless pass key, if nessesary connect a PC directly to your Netopia and reset the pass phrase through the routers control panel/gui, remember you will need to reset all pc conections to the new phrase. If you haven't made any IP changes to the netopia, the default settings are likely to be 192.168.1.254, just use your explorer to browse to this address
The Wireless have a Protection, if you see that message in Setup in your Router, write a phrase and pickup with you, all notebooks and pcs need this hexa key to enter in your Network,
*This key is enter in pc once, after is automatic. If you see this message on conect in your router, the Network have a password, please specify a Model for the instructions to removal and change.
