Technics SL-1200MK2 Turntable Logo
A
Anonymous Posted on Feb 19, 2014
New 33 button - Technics SL-1200MK2 Turntable
richard vreede
Level 2:
Sergeant:
  • Expert 432 Answers
  • Posted on Sep 21, 2014
richard vreede
Expert
Level 2:
Sergeant:
Answers
432
Questions
6
Helped
112405
Points
621
How to program my sanyogxdb remote to w ok rk my pioneer elite vsx 33 rece v er
To program your Sanyo GXDB remote to work with your Pioneer Elite VSX 33 receiver, you can try the following steps:
  1. Turn on the Pioneer Elite VSX 33 receiver manually using the power button located on the receiver itself.
  2. Hold down the "Code Search" button on your Sanyo GXDB remote until the LED light on the remote stays lit or blinks.
  3. Press the "TV" or "DVD" button on the remote, depending on which device mode you want to program the receiver to.
  4. Enter the corresponding code for Pioneer receivers. You can find a list of Pioneer remote control codes in the instruction manual that came with your Sanyo GXDB remote or by searching online. Enter the code using the number buttons on the remote.
  5. Point the remote at the Pioneer receiver and press the "Power" button. If the receiver turns off, it means the remote has been successfully programmed. If not, repeat the process using a different code from the list until you find the one that works.
  6. Once the remote successfully turns off the receiver, press the "Code Search" button again to save the code. The LED light on the remote should turn off or stop blinking.
  7. Test the remote by pressing other buttons, such as volume up/down or channel up/down, to ensure it is functioning properly with your Pioneer Elite VSX 33 receiver.
If you're still having trouble programming the remote, consult the instruction manual that came with the Sanyo GXDB remote or contact Sanyo customer support for further assistance.
3helpful
2answers
How do I reset blinking code, 33 E, on Samsung French door fridge after power outage?
33 E code, hold energy saver button and the lighting button at the same time for 6 to 10 seconds
Technics sl d303
I have the same problem as mentioned above, does anyone know how to fix this pls. The 33 and 45 lights have stopped illuminating, hence cannot get the record to start playing. There not burnt out as the 33 has flickered off once powered on. Start / Stop button does nothing. Strobe still works, it's in mint condition and has had little use but suspect the kids have been messing with it.
Denon DP-61F Turntable Rotates Slower than 33.
The answer lies in that 33 button. The connections to the should be followed and investigated why it does play correctly when held.
1helpful
How to replace rear wheel bearing on 1994 bmw 325i
3-Series (Except M3, M Roadster, M Coupe, 318ti & Z3)
1. Raise and support vehicle. Remove wheel(s).
2. Remove axle shaft. See appropriate AXLE SHAFTS article.
3. Remove brake disc. See BRAKE DISC .
4. Screw special tool (33 2 116) onto drive flange with wheel studs. Drive out drive flange with special tool (33 4 201/202/203). See Fig. 33.
5. If necessary, pull off bearing inner race using special tool (00 7 500) and a thrust piece. See Fig. 34.
6. It may be necessary to remove inner wheel bearing race with the following procedure:
  • Detach wheel bearing inner race with special tool (33 4 400) through groove in bearing inner race.
  • According to outside diameter of bearing inner race, use special tool 33 4 401 with: 33 4 405 for dia. 45-51 mm, 33 4 406 for dia. 50-55 mm and 33 4 407 for dia. 55-61 mm in groove. See Fig. 35.
  • Tension special tool 33 4 401 with wrenches 33 4 403 and 33 4 404 until it can still just be turned in groove. See Fig. 36 .
  • Screw in special tool 33 4 402. Detach inner bearing race.
7. Remove circlip. See Fig. 37 .
8. Remove wheel bearing with special tool 33 4 031/ 041/ 042/ 043/ 045. See Fig. 38 .
CAUTION: Do not reuse old wheel bearing.
9. Draw in new wheel bearing with special tool 33 4 041/ 042/ 043/ 047. For inner bearing race 42 mm use special tool 33 4 049 and for 39 mm use 33 4 046. See Fig. 39 .
10. Installation is reverse of removal.
11. Replace stretched or damaged circlip. Ensure correct seating.
12. Pull in drive flange using special tool 33 4 041/ 042/ 043/ 045/ 048. See Fig. 40 .
13. Install brake disc.
14. Install axle shaft.
Why my technic 1200 is playing 45 at 33 and 33 at 45?
Have the buttons been swapped around?. 33 should be on the left.
2yr old daughter hit some buttons now it won't - pau 33 pau 33
did you get this fixed? how? my 2 year old son did same thing.
My 33 & 45 speed giving problems
HELLO
I have just posted a cure for this deck, it is to do with the microswitches under the speed select buttons - they need to be replaced. Just repaired mine today - now there are no more problems selecting speeds.
If the speed goes back to 33 when the deck is switched off, this is because 33 is the default.
ALL THE BEST!
3answers
Codes
Telewest
C3 40 78 A2 B2 1C 84 F9
2A 09 4D DF CD 33 00 B9
Zen Microphoto MTP drivers not installing, stuck in loop
Make sure you have media player 11
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
Download recovery tool off creative's website.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
If that doesn't fix it try the USB cable
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
