Home Logo
A
Anonymous Posted on Feb 19, 2014
Vitrifiye rubbers have worn out and I want to buy new seat
1 Related Answer
Anonymous
  • 29 Answers
  • Posted on Dec 08, 2009
SOURCE: I need a new seat unit for my baby jogger city
hi come to us www.buggypitstop.co.uk will repair and sell parts for baby jogger in the uk
Luxline 160e. Why does electric window keep coming out of rubber guide?
not aligned correctly or the rubber is too new put some armor all on it, or check to make sure the rubber is seated I there good, if it is new its just new and needs to be used a bit if it is not new its worn out replace the guide.
Seat to fit a gural vitrifiye toilet with washer screws
Explain what you mean by washer screw?
Aug 26, 2014 • Home
How to mend a running gural vitrifiye toilet cistern
With lid removed, look down into it and remove and replace the black rubber thing in the center. This is the flush valve and is worn to the point where is no longer provides a tight seal allowing water to pass and run into bowl. Also, could be something underneath it not allowing it to seat properly.
Aug 26, 2014 • Home
Toilet seat gural vitrifiye
I need a toilet seat.
The present one has the words GURAL VITRIFIYE on the lid.
It is a D shape and has concealed rubber fittings.
The hinge sockets are 19 cms apart.
The seat is 35 cms wide and 45 cm max length from front to back.
Thanks.
Can you advise please?
1helpful
1helpful
97 ultra cant find gas leak under engine all fuel lines and pump good
You could have a needle in seat leak. Take apart your carbs and the little pointy rubber needle could be cracked or worn. The end of the rubber point should be perfectly cone like. A worn out needle and seat would have a imperfection in the cone. This makes it so that the bowl fills up with fuel and goes out the overflow- instead of the the fuel stopping when the floats get up to a certain level.
2helpful
2answers
Worn seat wheels on Tunturi 202 need replacing
Good News! Home Depot sells (on-line only) drawer rollers that work PERFECTLY for the Tunturi Rower machine seat rollers. The only difference is the wheels are nylon instead of rubber. Model Number R7228, Internet Number: 100142874. Item description: ROLLER, W/ 1/4" -20 STUD, 1-1/8" NYLON, BALL BEARING. There are two rollers in a package, $5 for two! http://www.homedepot.com/buy/prime-line-1-1-8-in-nylon-ball-bearing-drawer-rollers-2-pack--r-7228.html
Top Villeroy & Boch Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Villeroy & Boch Home Expert? Answer questions, earn points and help others
