Connex 3300 240-Channels Base CB Radio Logo
A
Anonymous Posted on Feb 19, 2014
NO TRANSMITT - Connex 3300 240-Channels Base CB Radio
A
Anonymous
Failed driver final transistors or voltage supply to driver and final
if your RX is aok then chances are the PLL and TX mixers etc are aok leaving only the first answer or a broken mic or TX switching circuit caused prob by a bad mic cable
How to adjust audio very poor modulation on transmitt
did you turn the wrong variable? did you experiment?
Yaesu FT-480R has no receive or transmitt
Hi Bob,
Great radio that you have there...
To get the best advice and info, do the following: join yahoo group specific to your radio Make/Model, the expert team there will be only to happy to assist, you can also download manuals, schematics and other goodies for your radio. All this is free.
I certainly hope I have been helpful to you.
Cheers,
Peter
1helpful
Have a 959 galaxy that will not transmitt
It could be the switch or the relay to look at first- See if the relay contacts close- if not trace that circuit, it might be a defective microphone switch.
If you do get relay action, check for voltage at VR10, VR12 and VR14
These are biases, so they may not be "high" voltages when using an analog meter.
If you have voltages, the final is likely dead. If you do not have voltages, tie to look for bad solder joints and broken resistors.
2answers
I have a texas ranger free spirit tr127fs it has no transmitt but the light come on when transmitt is pushed what is wrong
The first thing to check in this is the mic. If the mic is fine, then the next thing would be to check the final transistor. If it blows, then you will not transmit.
Doesn't transmitt data. What is the problem. No
Polar recommends sending to service center for battery replacement:
http://www.polarusa.com/us-en/support/product_support?product=411&category=FAQs&documenttitle=Servicing+Your+Polar+Product+-+Polar+USA&document=/gip/PEUS1kb-public.nsf/85256f470048b0bcc22567dc00599452/85256f470048b0bcc225743a0035cc4f?OpenDocument
Some daring folks try replacing it themselves..I am not recommending it, but here is the link..please be sure to read all the postings for a ll the info...again, not recommending it..just an fyi
http://forums.roadbikereview.com/showthread.php?t=108158&highlight=polar+transmitter+repair
Please let me know if anything helps,
Thanks
Will not transmitt after triple 520 final kit install,will receive fine
rather than use a small linier you decided to break your radio instead . It still sounds like a cold solder point to me .
1helpful
Refurbished dx 959 from galaxy no modulation? no transmitt?
If there is no transmit at all, it sounds like it wasn't fully refurbished. If it is just low modulation then just turn VR16 and VR14 all the way to the left.
If its not working at all, send it back. It hasn't been refurbished.
Fax Report Question
i believe it means rx receive and tx transmitt
in rs 232 communication (serial communication modem fax etc) line 2 is tx (transmitt and 3 is receive rx hope that helps
Experimental set up for wireless transmission
Yes it is possible to transmitt electrical power without wires, just not likely from your generator.
Go search for Nicoli Tesla on the web, he was a very smart fellow who did lots of work on this long ago.
Carl
Top Connex Radio Communications Experts
ADMIN Andrew
ADMIN Andrew
Patrick Patterson
Patrick Patterson
Level 1 Expert
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
