Even when i push the Warm-up and the Exercise buttons shows the E09 error
Hi! It is a problem related to the internal sd card under the battery place. Assistance solved changing the sd card.
Hello all well. it is the same problem I've tried to reset but did not work. I appreciate if you can answer.
What I had to do is simply remove the mini SD card and insert it again. Is located inside the device, you can find it removing only 1 screw that is behind in a small squared cover up in the middle
