All i need to put password to my accese point (dlink) please tell me how ?
Setting up a wireless router with a Windows client can be complicated.
There are a number of measures and options that have to be understood, and it's all too easy to make a mistakes but D-Link provides an easy to walk through configuration system to help you set up your D-Link wireless router.
Plug one end of the Ethernet cable into the DSL modem.
Then plug the other end into the "WAN" port on the back of the D-Link wireless router.
Connect wired computers to any of the other Ethernet ports on the router using another Ethernet cable.
Access the D-Link Configuration Screen
Open your web interface and type "http://192.168.0.1" into the address bar, then hit "Enter" or "Return."
Use "Admin" as the username and leave the password blank when the login screen appears.
Click "OK." You should now see the D-Link configuration screen.
Set Up General Security
Change your administrative password by clicking on the "Tools" tab and choosing the "Admin" button.
Enter a new password under the "Administrator" heading.
Confirm it, and click "Apply."
Disable the wireless Local Area Network (LAN) if you don't need to use the wireless access and you want to make sure no one else is able to access your network.
Under the "Home" tab, choose "Wireless" and select the "Off" option.
Enable Wireless Encryption Protocol (WEP)
Locate the "Home" tab in the D-Link Configuration screen, and click on the "Wireless" button.
Use the "Open System" button beside "Authentication."
Select the "Enabled" button next to "WEP," and set the encryption key to "128 bit."
Set the "Key Type" to "ASCII" and choose a 13-digit password for the "Key 1" field.
Write down the password in a secure location.
Click "Apply." Change the SSID
Change the SSID to make it more difficult for others to locate and use your network by clicking on the "Home" tab and locating the "Wireless" button.
Change the default SSID to one of your choosing, then click "Apply."
Disable SSID broadcasting. Under the "Advanced" tab, click on "Performance" and check off the "Disabled" box. Again, click "Apply."
Filter MAC Addresses
Click the "Advanced" tab in the D-Link "Configuration" screen and select the "Filters" button.
Choose the "MAC Filters" and click on "Only Allow Computers with MAC Address Listed Below to Connect to the Network."
Enter the name and MAC address of the computers allowed to access the network, beginning with the one you are currently configuring. Click "Apply."
Get online
and got to www.google.com In the google search box type: "Dlink
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Look for Manuals.
The IP address to put in your browser to get into the router is: 192.168.0.1
The default userid is: admin
There is not default password, so leave it blank.
