The electric heat bank is out. Why doesnt the heat pump come on?
SOURCE: how to tell if your unit is a heat pump or just air conditioner with electric heat strip
PTH is a heat pump. PTC is an air conditioner only. I don't believe Amana makes electric heat strip-only models based on what I see in their literature. You can just do a google search and look for yourself.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
the control board had previously been replaced. the floors were sanded and the heat strip over loaded. the a/c will come on when set.
