My laptop came with windows 8 and had no disks come with it. i am trying to do a factory reset, and i cant seem to figure out how to do so without the recovery disk
SOURCE: need to factory reset fujitsu laptop
The label on the bottom of the laptop should give you more detailed information about the model number.... when you say you can't log on.... what exactly are you referring to ?
Robert
SOURCE: Acer Aspire 5315 No Recovery Disk - Restart
yes you can use the recovery partition which should be built into the hard drive. press f2 on the bios screen and follow the on board instructions. this will return the laptop to its original factory state. Keep in mind that this is a destructive reinstall of windows and you will lose all data and programs.
make sure you do a recovery and NOT a system restore to earlier date.
hope this helps.
SOURCE: Acer recovery disk download
http://www.restoredisks.com/index.asp
Just ordered for my acer aspire 5315
SOURCE: How do i reset my everex stepnote laptop to
I have an NC1500 PC Notebook. it will start up but nothing shows up on the screen?
SOURCE: Where do I find the recovery partition on my toshiba l645d laptop with windows 7?
The recovery partition is basically the same as the Toshiba restore CD if your model has one. The restore partition is located on a separate partition on the hard disk (if it has one).
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state.6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
