Star button on vtech 6.o does not function properly
When I press the star button a number 1 shows up on the screen. So, since I use Verizon and the messages need to be retrieved by pressing *86, I cannot get to my my messages. I did speak with their tech who told me they can't change their setting to say, 186, or #86 as their system is only designed to recognize *86. Just bought the phone yesterday, a Walmart special (haha) no less. Suggestions possibly?
All releases of Partner
Lets say that you currently pick up line 1 to make an outgoing call,
but you want to pick up your last line (in this case we will say we have
6 phone lines).
This feature is called "Auto line select"
To program Auto line select:
From extension 10 or 11:
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Enter the extension number of the extension you need changed.
press ** (start, star)
Then the order you want the lines to get picked up
Then ** (star, star) when done
When finished, press feature 00 to get out of programming.
So, in this example I would enter my extension number (22) and press
** (star, star) and press line 6, line 5, line 4, line 3, line 2, and
line 1. Then I press ** (start, star) to signify that I am done
programming Auto Line Select. And feature 00 to get out of programming.
Easy as pie.
press # P will appear after pressing *button quickly 3 times (star star star) W will appear after pressing *button quickly 4 times (star star star star) + will appear after pressing *quickly twice (star star)
3. The phone will show SIM Restriction Off and is now unlocked hope this helps
1. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash) turn off the phone 2. take out the battery and sim and put wrong network SIM and insert a half of it, so it won't ask for network password and shows "Insert SIM" message. Now put the battery ,and switch the phone on .(phone shows "Insert SIM" message.) 3.With out turn off the phone push the sim fully in. At this stage the phone is still asking to "Insert SIM" 4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash) 5. The phone should reboot working with "wrong" sim inside. 6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000# (star 7465625 star 638 star 8zeros star 8zeros hash) 7. Now Disable network lock By typing: #7465625*638*00000000# (hash 7465625 star 638 star 8zeros hash) Phone is unlocked (check with *#7465625#)
There is your unlock instructions for your Nokia Phone... Enjoy :)
***** DO NOT enter the unlock code more than 3 times on BB5 phones, if you do you will NEVER be able to unlock your phone by code *****
1) Power ON your phone
2) Type #PW+CODE+1# using your keyboard
The letter P appear after press 3 times quickly the button star ( * )
The letter W appear after press 4 times quickly the button star ( * )
The letter + appear after press 2 times quickly the button star ( * )
3)
The phone will show "SIM Restriction Off," in case it doesn't unlock
the phone, you will have to replace step 2 but use 7 instead of 1
4) Device is now unlocked
*** IF THE CODE IS REJECTED, DO NOT TRY AGAIN. ***
Substitute the 1 at the end with 7.
So 2nd time try: #PW+YOURCODE+7#
ie. #pw+000000000000000+7#
The letter P appears after you quickly press 3 times the button star ( * )
The letter W appears after you quickly press 4 times the button star ( * )
The letter + appears after you quickly press 2 times the button star ( * )
The phone shows "SIM Restriction Off" and is unlocked!
The error code mean your fixing heater isnt getting warm in a specific time.But it can be caused by a power dip.
So try this.
Press the star button and then the no 2 and 8 together press star again.Then you are in service mode.
In service mode sellect "copier" and then "Function"and then"clear"ant then"error" and press the ok on the screen.Swiths the machine at the plug off and on.
And Katchiiing!!!
If it doen't help you will have to contact your Canon dealer to replace that Fixing.
