Toshiba 50HP66 50 in. Plasma Television Logo
Posted on Jun 10, 2009
Tv does not power up, has red light flashing on lower rh corner.
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Jun 10, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
13625
Points
20
Just check the standbye circuit and power supply pls veryfy the protection circuit also
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
My LG 32CS460-UC will not turn on It has a red light flashing in the lower right corner
the psu has failed prob a CCFL fault as it flashes red
the low voltages like 5v is ok
get it serviced by a tv person i think its more too do with the lcd panel
My sharp LC-46SV50U wont turn on
get the service manual and then open it up and do a voltage check on the 5v standby.
if it's not showing anything, then you need to hunt down if it's the ic, cap, or diode or a combination thereof.
The tv has power .the red light is on ,but when it turns on,the green light comes on but then it turns right back off ant the light goes back to red it has a round 1/2" button like plastic plug in...
Tod,
The little plastic button you are referring to is the IR receiver for the Remote. When the TV turns itself off, are there any flashing lights on the front or rear of the unit. Look through the vents in the rear for any flashing lights or try tuning the tv on in a dark room and see if any lights flash and reflect off of walls. If there are flashing lights tell me how many flashes and what color and I will try to look them up in the manual.
Picture has become darker and darker, but now there is no picture or sound a red flashing red light in the lower right hand corner.
Time to replace lamp in tv.
Existing lamp in tv is dead and tv needs new lamp to work again.
Lamp replacement procedure is easy and written in user manual of tv.
The TV will not turn on. When the switch at the lower left corner is pressed the light in the switch flashs green for about 4 seconds as the TV seems to go through a start up procedure. Then the light...
The red flashing light is the service code. My guess is the power supply is bad now, but it could be something else. If the TV is under warranty, take it in and get if fixed. If it is not, then you may try to check the power supply first. Count the flashes of the red light and check online for the issues when this model flashes, 4 times or 6 times... or 9 times, etc.
2helpful
Suddenly pic went out. Loud crackling and popping heard. Now, Blue indicator and red power light continually flashing. I think lamp. Unit 3 years old
the lamp has blown replace if got instruction book that came with tv shows you how if not got the lamp is behind cover on side or frount cover that comes off by undoing two black screws on back corners (each lower corner) anda sharp pull will remove cover
Panasonic 32 inch LCD TV will not turn on-red light flashing
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
3helpful
2answers
sounds like a hardware failure, let me know which model # it is and i will run through service manual.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
