I took out something and did not close the door immediately. When I did close the door, the light remained on and the top vent comes on, very similar to when it is cooking. The Stop button does not do anything. I unplugged and replugged; didn't correct issue. I can still enter a time and start oven. Any ideas?
SOURCE: I have a Maytag microwave MMV5207 - we were using
sounds like the switch broke.your going to have to be creative and like ...tape a toothpick in the hole just right. or something
SOURCE: non-working microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Maytag over the range microwave won't start
It sounds as if your keypad has failed.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more
information & DIY help and/or an estimate.
We're
happy to help you with free advice and we'd appreciate your thoughtful
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
SOURCE: Microwave runs constantly
you have a door inter lock sw/ failure . replace the sw. there 3 .. ir they click there probably good . one of them does not click . primary sw secendary sw . and mont sw . .. a very common problem with all brands of micro's //
Am I to understand that everything works fine but the vent fan and cooktop light stay on all the time?
