SOURCE: INCLINE ERROR ON LIFE FITNESS 95 T TREAD??
hi
check the home switch
it is indicator of elevation
when you look under the tredmill where elevation motor you will see white plastick pin coming down through the hole just check it if still there and pressed it is usually 95 % of elevation problems
if it is not then open the hood and check elevation connections
let me know if it is not these problems post it i will give you system check code
thank you and good luck
