The local Husqvarna agent is the best place to start, e bay is also a source of pattern parts for Husqvarna machines, the part no. for the coil is 545046701
The pick up coil is in the dist .the rotor under the rotor has
a pick up star that passes by the pick and send spark to plugs
but just be sure you have current at the coil if not it comes from
the ingniter but you schould start at the beginning like clean
the battery post -1st then ck current going to coil -also
there is two fuses to ck for ing after that see if you can hear fuel pump back at the tank if you can hear pump ck the spark plugs and see if your getting a spark from them great start let me know
also whemyou looking at dist make sure the main coil not cracked
they heat p and crack please let me know
Check the piston is not scored by removing the muffler and looking through the open exhaust port, if ok, remove the spark plug and check for a spark, if there is no spark it will require a new ignition unit.
Hi orvil brad hear I would check the ing. fuses you have at least one and maby two in the inside cab fuse block, and also one or two in the engine bay fuse panel, there is also a relay located in the eng. bay panel, also you may check the ing. wire that goes to the coil system, This wire will have no 12volts until the ing. switch is turned on then it will show 12volts. It has a habit of coming loose at the coil sometimes. Good luck
first check for power at distribuitor terminal if pwr replace ing coil, if no power check ing switch, also a common problem is some one accidentally cause a spark or short one of the fuse links by the starter may be open check them all.
