Cannon ir 3300 xerox machiene
The reading of the main thermistor does not reach 30C 1 sec after the main power switch is turned on. Or, it does not reach 70C 2 sec thereafter
The fixing film unit is faulty. The main thermistor has an open circuit. The fixing heater has an open circuit. The main power supply PCB is faulty. The DC controller PCB is faulty. To reset the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
First clear that error from service mode. Press additional function
press 2 and 8 together
press additional function agian
service mode should appear in screen
select copier
select function
select "clear"
select "err"
select ok.
unplug power cord for a few seconds and restart the machine
try to make some copies if problem persist replace the fixing heater assembly
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
SOURCE: My xerox machine cannon IR
E007 - Fixing film rotation error
You have to disassemble fuser unit and inspect a fixing film, if damaged - replace.
The official documentation says:
E007 0000 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
