Kuds25shwh1
SOURCE: LIGHTS FLASHING ON THE PANEL
If the reset procedure (those buttons you pressed) didn't work, it's because the machine is still reading a fault. It could be a few things... water temperature too low (indicating a bad heating element), partial blockage of the drainage hose, or something preventing the spray arm from spinning. If letting it sit for a while allows it to start again, I suggest you do that. It will stop again and the lights will start blinking. When it does, open it up immediately and see how much standing water there is. If there is a lot, look for a blockage in the drainage hose. That's the most likely, I think, because it makes sense that it would work again once the water slowly drained. If there isn't much water, then see if the water that is there is hot. If it's not, then it's the heating element. Checking for movement of the sprayer arm is a bit trickier, as it won't be moving while the thing is open. Though, if the first two are not the problem, there's a good chance that is. Or, of course, it could be a malfunctioning control panel giving false errors. There's really no way to test for that, unfortunately - but I don't think it's acting like that is the problem.
SOURCE: SANI RINSE LIGHT KEEPS BLINKING
hi
have you done some troubleshooting with it? try putting only 1 plate to clean. would it still have the same problem?
i would suggest that if you see the water doesnt drain, check if there are any blockages at the bottom.have it regularly clean as some components in the inside might get particles left from the water and not from the dirty plates.
hope this helps you.
