As written above... "I bought a "Dazzle" gadget,that transfers vhs to DVD but lost the software & don't know how to install/use it?" HELP!!!
To myself i seem to have been only like a boy playing on the seashore and diverting myself in now and then finding a smoother pebbles or a prettier shell than ordinary whilst the great ocean of truth lay all undiscovered before me.
Search in the google dazzle gadget and the model number dwnload your software
SOURCE: Pinnale Dazzle DVD recorder doesn't recognize VCR
On the start up of the instant DVD recorder program, you can either use the "let the wizard guide you" or "advance mode"
1. Select source:
you should select the options:
Video standard NTSC (Because this is the default in our region)
Video composite - if you are using RCA (red, yellow and white cables)
S-video - if you are using the cable with several pins in it.
2. Select Burner
You should select the options:
Hard disc folder - if you will be saving the content in your hard drive, the format of this files are DVD such as VOB and IFO etc.
TSST - _ _ _ _ - if you will selecting your DVD drive.
(If you have selected your DVD Burner and you cannot click "next" to proceed to the Third option,
this means that your DVD drive is not able to burn a DVD)
3. Select menus
It must be NO
4. Recording
select total recording time (make sure that dazzle is selected in the "select source" to set the total recording time)
SOURCE: I have a Dazzle DVD
It is becuase the dazzle device is not selected as your video source. Please try to go back to step number 1 then click the box says pinnacle file capture then select the dazzle then try it again. :-)
SOURCE: no audio when using "dazzle" dvd recorder
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Dazzle/Dazzle+Video+Archiving/Dazzle+DVD+Recorder.htm?view=knowledgebase
Try looking here start there and maybe it will help you out
SOURCE: I bought a Dazzle dvc100 a year or two ago, And
Try these links
wareseeker.com/free-dazzle-dvc-100/
forums.cnet.com/5208-7591_102-0.html?threadID=198849
www.pcreview.co.uk/forums/thread-651892.php
SOURCE: VHS direct to DVD
If you already install your dazzle to your computer double click on IDVDR Icon and then choose advance mode. Click on step number 1 click the pull down arrow and then choose your dazzle dvc device thing, Put your DVD blank disc to your writer and then on step number2 click the pulldown arrow and then choose your DVD writer. Click the prepared button. for the full details check this link.
ftp://ftp.pinnaclesys.de/Manual/InstantDVD_Recorder/Instant_DVD_Recorder_ENG.pdf
That is the manual for your IDVDR.
