SOURCE: Kodak EasyShare Z612 will not format SDHC 4.0 GB
Z612 is not compatible with SDHC card., the compatible and recommended Memory card you can only used is 1GB SD card or 2GB SD card. Gudluck!
SOURCE: how to replace the lcd screen on a kodak z612
open the case of camera using small screw driver
SOURCE: How can you format a SD 4gb card for the Kodak
You can't. The Z612 uses SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card and is incompatible with SD devices.
For SD cards (2GB and smaller), you'll find the Format operation in the Setup menu. Press the Menu button, then use up/down to select the wrench, then press OK.
SOURCE: I have not been able
The problem is that your camera is only compatible with SD cards, not
SDHC cards. You bought a larger card for your older camera, not
noticing that it was SDHC (or not knowing that it mattered). The new
card can't be formatted, not because it or the camera is broken, but because
it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC
cards but some have errors; they disable half of the chip and sell it
as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because
they're cheaper, but 4Gb SD cards do exist. They are so rare that I've
even seen a guru on this site claim they don't. I did own one once, but
it was very expensive and turned out to be so unreliable that I had to
return it. I don't recommend
looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it
doesn't say "SDHC" on it.
