The real problem with the Comcast remote is that there is no other
brand, it's not like a Sony remote that's relabeled or anything.
Fortunately, Google helps again, and it turns out Comcast has a page
online about programming the Comcast remote control.
Comcast 3-in-1 remote control
To program the remote to work with your Sony TV, you need to take the
following steps:
Find the code or codes for your TV from Comcast's list [PDF]
Turn your TV on
On
the remote, press and release the TV key on the very top of the
remote.
Press and hold the Setup key, until the "TV" key
flashes twice, then release the "Setup" key.
Using the number
pad, enter in the first 4-digit code found next to your television brand
on the chart. If you do this correctly the "TV" key will flash twice.
Now it's programmed!
Now point the remote at your TV and press
the Power key. If the TV turns off, you're golden. If not, try
again with the next code on the list.
If you go to Google an put manual for a Comcast remote control it will give you an option saying, Comcast remote codes, program your Comcast remote control, that will give all of the remote controls just look for yours and download or check the manual for it so that you can program it.
Are you using Comcast remote to control the TV? When you program the Comcast remote to control your TV, it will do two functions: on/off, and Volume control. The Comcast can also be programmed not to control the volume of the TV (TV volume will have to be set at about mid level manually, then the Comcast box will send out variable sound level to the TV), just on/off ONLY.
