Two coils in toaster broke causing toasting on on side. How can I fix it?
SOURCE: how do you clean an
Generally, there is a latch which closes the door on some units...on others it is electrically actuated. Turn the controls to clean. Generally, there is a function control and a temperature control which must be activated. This will latch the door electrically. A two hour cycle is about right for most soil, if you're given a choice. Ventilate the area...it smells! The door will unlatch about half an hour or more after the cleaning stops.
SOURCE: Modern Maid Wall Oven DGO757 ignitor gets
I have a Modern Maid Wall Oven and the pilot light waant stay lit. What's the best solution?
SOURCE: How do I remove the
Hi Please click on this link to follow the step by step
instructions that will help you in removing the door. Hope this helps...please post back for further assistance. Daniel
