How to Program hannspree remote to hannspree tv
To program a Hannspree remote to a Hannspree TV, first turn on the TV and then press and hold the "Code" button on the remote until the LED light turns on.
Next, enter the four-digit code for the TV using the number keys on the remote. If the TV turns off, press the "Code" button to save the code. If it doesn't turn off, try another code until you find one that works.
If you cannot find the four-digit code for your Hannspree TV, you can try using the code search feature on the remote. To do this, follow the steps for programming the remote but instead of entering a code, press and release the "Code" button and then press the "Power" button repeatedly until the TV turns off. Then, press the "Code" button to save the code.
If you are having trouble programming the remote, make sure you are aiming the remote directly at the TV and that you are not too far away. Also, check that the batteries in the remote are fresh and properly installed.
If you accidentally program the remote to the wrong TV or if you want to program it to a different TV, you can reset the remote to its default settings by pressing and holding the "Code" button for at least three seconds until the LED light turns off. This will erase any previously programmed codes.
