I've been trying to print a document, and when I open up active printers, it says it's pending two different documents. The first one is from 2 days ago, status says "deleting-printing". So, I've hit cancel all printing documents, it will cancel the most recent request first, however, it still refuses to cancel the 2-day old print job. And then, when I try hitting restart, it comes up with the error msg "error processing command".
I'm out of options...and am in DESPERATE need of my printer!
Assuming you have a modern windows pc, You will need to manually stop the print service. Do this by running the command "net stop spooler" from the "run" line. Then go to "C:\WINDOWS\System32\spool\PRINTERS" and delete all the files from there. After these files are gone, start the spooler service again by running "net start spooler". You should be all set after that.
