The air temp is correct the pool reads 171 but if you press the temp button on the Jandy Control panel outside it gives the correct pool temp. Solar heater won't come on hand held says enabled and spa heater won't come on it says enabled. does the panel pull its temp from a different probe or from the chlorine generator's sensor?
The chlorine generator is giving you a correct readout of your pool temp. however, your water temp sensor is bad. if you look at your filter pump, follow the pipe coming from the top of the pipe, until you see a metal clamp. withthe system off, remove the clamp and pul out the sensor from the pipe and replace with a new 10k ohm temp sensor. NOTE: Older Jandy systems used black temp sensors, the new sensor may be slightly larger. use a masonry drill bit to bevel the old hole out for the new sensor, and replace the wires.
youll need a cordless drill and a drillbit to match the same size as the new sensor. Drill very slowly and very carefully, so you dont go through both sides of the pipe, just the top. I prefer to use masonry drill bits. There are 2 ways to rewire the sensor, the first would be to splice into the wire close to the sensor, using waterproof connectors, connect the red to the red and the black to the black. The 2nd way to rewire the new sensor in, would be to remove the front panel on the outdoor control box, then trace the wires back to their place on the green bar and replace them with a small flathead screwdriver.
SOURCE: Same Issue
the pump stop so will not drain spa dip # 4 may turn off for the delay but not sure if the pump will still turn off since this is new tech. good luck
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
