Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
Brenda Cates Posted on Feb 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to know if 150 yamaha is 2 stroke or 4 stroke
Lamarque Billy
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 07, 2015
Lamarque Billy
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
600
Points
9
Almost all new Yamaha 150 are 4 strokes.If you do not need to mix oil to your fuel tank then it is a 4 stroke.
rilaxson
Level 2:
Sergeant:
  • Expert 456 Answers
  • Posted on Feb 17, 2014
rilaxson
Expert
Level 2:
Sergeant:
Answers
456
Questions
0
Helped
69745
Points
719
They make a 2 and a 4stroke.A 150F is a four stroke
2answers
I own a Yamaha 150 HP 4-stroke. By mistake, I added a gallon of Yamalube when filling my tank (1:55 mix) (something I do for my older 2-stroke engine). Is this a problem?
I always add about 10% oil to my small engines to help protect them from friction. If it starts ok with that much oil, it might smoke a bit and cause a little carbon build up on the plugs or valves, but most engines after 1980 are high enough heat and compression ratio to clean themselves up.
Sometimes the oil doesn't blend in all the way without some sloshing around.
What is the float setting for an '04 150 Yamaha 2 stroke
Every 2 stroke I've ever worked on, the float is set parallel to the bottom of the carburetor. Turn the carb upside down and look to see if the float is even with the bottom of the carb.
1helpful
Hi there I have a outboard Yamaha 2002 4 stroke 60hp I just want to know what's the reading psi compression Test should be thank you very much cheers
same as a car engine
150-165 psi with a variation of no more than 10% between cylinders
contact a service center and ask them for the compression pressure and how to do the test
1helpful
2answers
1989 yamaha waverunner. I purchased a 1989 25HP Yamaha Waverunner & was wondering how you check the engine oil?
Did you get any instructions from the previous owner? If it's a 4 stroke waverunner there will be a dipstick on the engine block, but I'm guessing it's probably a 2 stroke engine because most watercraft used 2 stroke motors clear through the 1990's. The oil will be mixed with the gasoline when you fill it, bottles of 2 stroke oil can be purchased at most stores that carry oil. Your waverunner can be mixed at 50:1, which equals out to be 2.6 oz of oil per gallon of gasoline. On a 2 stroke engine the engine gets lubrication from the oil mixed with fuel and will burn up fast if straight gasoline is used. Let me know if you have any troubles, but try to get ahold of the previous owner to get some more info.
Daniel
2answers
Does a yamaha 2003 atv have four stroke engine?
Do you mix oil into the gas?? Is there a place to check the oil (a dip stick). Is there a special place to put 2 cycle oil for a self mixer?
If you don't mix the gas with oil and there is no special place to put 2 cycle oil, you have a 4 cycle engine.
If there is a place on the side to check the oil level, you have a 4 cycle engine.
Next question will be ... how do I check the transmission oil? If you have a 4 cycle engine, the engine oil is also the transmission oil ... rule of thumb.
You are showing a picture of a motorcycle and asking a question about a ATV, but not mentioning a model number. I don't think Yamaha is currently making a 2 stroke engine for their ATV's (there are several sizes - not including assorted models for sale around the world ... and I don't know where you are writing from (and please don't say).
Maybe the best thing for you to do is call the Yamaha dealer on Monday morning and tell them the model you have and ask the question 2 stroke or 4 stroke. There will be no more guessing on your part then.
Make sense?
Thanks for your question @ FixYa.com
3helpful
Would like to know the gas tank capacity for a 1996 xvz 1300 a royal star yamaha cycle, and tire size please
YAMAHA ROYAL STAR Engine Type: 1294cc liquid cooled 70 degree DOHC V-four, four valves per cylinder
Bore and Stroke: 79 x 66mm
Compression Ratio: 10.1:1
Carburetor: 4 x 28mm Mikuni CV
Transmission: 5-speed
Wheelbase: 66.7 in.
Dry Weight: 701 lbs.
Tires: Front; 150/80V16 Rear; 150/90V15
Forks: 43mm Kayaba
Rear Suspension: Kayaba mono-shock with adjustable preload
Brakes: 298mm dual front discs with dual-piston calipers; 320mm rear disc with dual-piston calipers
Seat Height: 28.3 in.
Fuel Capacity: 4.8 gallons
Yamaha india
hello Sir,
It was the phase between 1990-1995, when Yahama lost to Hero Honda, as v know, Yahama was an expert in 2-stroke engine bikes, as v know 2-stroke engine will yield higher power but NO good mileage, n emit more smoke.
so...GOV OF INDIA phased out all production of 2 stoke engines in the country, so yamaha had to stop the production of Yamaha RX n RD series in INDIA.
N constantly rising fuel prize, utilizing this need form d public Hero Honda's CD 100 hit the market, with 4 stroke engine n heavily improved mileage.
hence Hero honda won the race...
Although Yamaha came up with some 4 stroke models, but those didnt click it for them, but now its again yamaha's time !!
with introuduction of Yamaha R15, FZR , really yamaha is back with a bang !!
thank u so much..!!
plz vote me/ rate me ..thank u!!
Top Light Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
john h
Are you a Light Boating Expert? Answer questions, earn points and help others
