Question about Microsoft Excel 2010
I have entered "=SUM(B12:G12)" in a cell in my Excel 2010 Worksheet - The result is"0.00" rather than the correct total?
One cell in the Worksheet works correctly - The result give me this result
6ya staff
SOURCE:
Anonymous
SOURCE: Micosoft Excel
Ctlr and tab
Posted on Dec 04, 2007
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: import data from access into excel where one column go into one worksheet and other into next
Can't be done.
Access will only put the data into one worksheet. It is very picky when it comes to exporting data into an Excel spreadsheet.
There are two ways to get around it:
1) You can export the data from Access into two files. One for the the first worksheet and another file for the second workshet.
2) You can import everything into one spreadsheet and build a macro into Excel to cut the information one spreadsheet and paste it into the other if this is a redundant task to do all the time.
Hope that helps you out.
Posted on Jun 10, 2008
Anonymous
  • 189 Answers
SOURCE: How to copy Excel worksheet in a word document?
go to Insert > File >select file and insert.
you have to select all documents when you when insert box opens.
Posted on Mar 16, 2009
Anonymous
  • 407 Answers
SOURCE: FORMULA PROBLEM IN MS EXCEL
Are you trying to include the sum cell in your calculation - Check the formula bar.
Posted on May 10, 2009
ronanreynera
Ronan Reynera
  • 166 Answers
SOURCE: Problem was found in Micorsoft
Once you have copy the cell from where the formula cam from, on the destination cell,
go to
1. Edit
2. Paste Special
3. Formula.
4. Press Enter
This should resolve your problem. Regards.
Posted on Aug 18, 2010
How do you subtract on Microsoft excel
  1. Select a cell
  2. in the Fx section type =SUM(
  3. Click another cell
  4. The cell should highlight and the Fx should display (for instance =SUM(C3
  5. modify the Fx to read =SUM(C3-
  6. Click another cell
  7. Fx should read (for instance) =SUM(C3-D3
  8. Modify the Fx to read =SUM(C3-D3) by adding a closing bracket
  9. Put a number in C3
  10. Put a number in D3
  11. B3 will display the result of the subtraction
Mar 08, 2015 | Microsoft Excel 2010
Sum numbers in a column down until you come to a blank, then start again
Sounds like your issue can be solved readily with a pivot table.
If you give the columns of names a title like "NAME" and the number columns a name like "VALUE". All other columns should contain a unique name.
Then select the entire table, including the labels at the top ensuring that the range extends entirely over the column you need to sum the values of.
In Excel 2013, choose the INSERT menu and select the PIVOT TABLE command.
Insert the Pivot table into a new worksheet.
A new sheet will open with a strange-looking control panel on the right of the window.
Make sure that the box for NAME and VALUE (only) are checked
You will notice that Excel assumes that you want the SUM of the values for each NAME summed. The results are in the leftmost area of the worksheet.
If this works for you, please vote my answer as "helpful".
Sep 03, 2014 | Microsoft Excel for PC
My excel is starting right to left in window 7
The default worksheet direction in Excel 2007 or 2010 is Left-to-Right. To change a worksheet direction to Right-to-Left, follow these steps:
  1. In Excel Ribbon click on the Page Layout tab.
  2. In the Sheet Options group click Sheet Right-to-Left. The sheet direction will be changed. Column A will now be to the far right. Columns B, C, D.. etc. will follow to the left.
- See more at: http://www.exceldigest.com/myblog/2012/04/29/how-to-change-worksheet-direction-in-excel-2010-to-right-to-left/#sthash.lSG25YXq.dpuf
May 27, 2014 | Microsoft Excel 2010
How to calculate the percentage using the excel
Hide All
Percentages are calculated by using the following equation:
amount/total = percentage
Where percentage is in decimal format.
What do you want to do?
Calculate the amount if you know the total and percentage For example, if you purchase a computer for $800 and there is an 8.9% sales tax, how much do you have to pay for the sales tax? In this example, you want to find 8.9% of 800.
Example The example may be easier to understand if you copy it to a blank worksheet.
  1. Create a blank workbook or worksheet.
  2. Select the example in the Help topic. Note Do not select the row or column headers.
    Selecting an example from Help
  3. Press CTRL+C.
  4. In the worksheet, select cell A1, and press CTRL+V.
  5. To switch between viewing the results and viewing the formulas that return the results, press CTRL+` (grave accent), or on the Formulas tab, in the Formula Auditing group, click the Show Formulas button.
1 2 A B Purchase price Sales tax (in decimal form) 800 0.089 Formula Description (Result) =A2*B2 Multiplies 800 by 0.089 to find the amount of sales tax to pay ($71.20) Note To convert a number in percentage format to a decimal, divide it by 100. For example, the sales tax in this example (8.9) divided by 100 is .089.
Calculate the percentage if you know the total and amount For example, if you score 42 points correctly out of 50, what is the percentage of correct answers?
  3. Press CTRL+C.
Simple way Amount/Total*100
Apr 30, 2011 | Computers & Internet
What is default name in ms excel? how is possible excel worksheet in excel?
Book1.xls Do you mean that you can't find the worksheet you have establish and you haven't rename the file? The worksheet will be OK if it had been saved.
Feb 15, 2011 | Microsoft Office 2010
How do i insert a formula in a column to add each number & give a total at the bottom?
For example, you have three numbers from A1 to A3. On row A4, type =SUM(A1:A3).
That should do it. :)
Sep 16, 2009 | Microsoft Office Excel 2007
Count how many times a value appears in a column, based on anothe
Go to the cell you want this total in.
Type this formula:
=SUM(IF(Sheet2!C1:C10="EME",IF(Sheet2!N1:N10=1,1,0)))
make sure you end the formula with CTRL - SHIFT - ENTER which makes it an array formula. If you forget, go back to the cell with this formula and press F2 (to edit the cell) and press CTRL - SHIFT - ENTER to convert it to an array formula (Excel will show a little {...} around the formula).
Dec 21, 2008 | Microsoft Excel for PC
HELP with macro config
Hi Hss Holdings,
The easiest way to do this is to use a formula called vlookup. You need to have the raw data some where in the workbook, but it can be a separate sheet. Put all the raw data in a table, make sure the account number is on the furthest left column, then start entering the formulas
vlookup(value_to_find, table_to_check, column_index_number, range_lookup(true/false))
value_to_find = the value you want to find on the left most column of the table
table_to_check = the table you want to find the data from
column_index_number = the column number of the data field you want to return into this cell, 1 = the left most column.
range_lookup = false for an exact match, true for the nearest match
Say the table is on sheet2 between A1 and E300
B15 is whatever you type, so no formula needed here
B12 =VLOOKUP(C1,Sheet2!A1:E300,2,FALSE)
G12 = B12 =VLOOKUP(C1,Sheet2!A1:E300,3,FALSE)
etc
Jul 12, 2008 | Excel (SS8SATAS5128400R)
In Excel
   a                         b                 c                    d
1 item                     cost            qty                 =c1*b1
2 item                     cost            qty                 =c2*b2
                                                 total              =sum(d1.d2)
all quantities should be blank except for the items you want to total.
Oct 25, 2007 | Oracle 10g Database Standard (ODBSEONUPP0)
Budgets in excel
Dear Madiha35,
I would recommend the use of the Table Function in Excel.
Here are the steps in Excel 2007, if this does not work for your version please add comment for me to reply to.
Conversely, If you would like the softcopy of the screenshots, I would be happy to email them to you.
Excel 2007 had a budget format workbook
New workbook, Select Budgets in the last hand navigation, Select Personal Budget.
Step 1:  Enter your data into the worksheet.
Step 2:  Create Table
             Highlight the relevant data
             On the insert tab, click on Table
Step 3:  Verify Table range is correct, Click OK
Step 4:  Select the cell you where you wish to Sum Data.
         Click on Autosum.
Step 5:  To Insert new data
         Click on the sum row in the table, (Not the entire worksheet row)
         Right click, Insert, Insert Table rows from above
Step 6:  Enter new data in row
Step 7:  Data is automatically calculated in formula.
Oct 22, 2007 | Computers & Internet
Open Questions:
Microsoft Excel 2010 Logo
21 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
