Brother HL-6050DN Laser Printer Logo
Posted on Jun 09, 2009
Poor print quality....bad fuser???
Left side of page is dark and fades to a mirrored image on the right with identical results on the back of the page. I've replaced the drum and toner cartridge, ensured the corona wire is clean, wiped down the inside of the printer, and i'm using the recommended paper. The printer was moved recently and never had problems before. All components are at %88 or higher. I fear that the fuser has been damaged or may need to be reseated but unsure what to do next.
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Jun 09, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
0
Helped
36977
Points
36
Is the toner sticking to the paper? This could produce double images (but not mirrored) More likely a problem with a mirror in the write unit out of place, which could create "mirror" image and poor quality.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Why does my 6280 separate one image into two and print it?
Poor fusing of the toner onto the paper is caused by
1. Poor quality compatible/remanufactured toner cartridges that have the wrong toner in them. - Use OEM, or better quality independent toners (and complain to your current supplier about the ones you have)
2. Damp media - high moisture content in the paper prevents correct fusing. You'll probably see the paper 'steaming' as it comes out if this is the case. - Keep your paper dry, only load as much as you need.
3. Thicker than normal media. The thicker the paper, the longer/more heat it takes to fuse the toner. - Make sure you have the correct paper type set in the printer driver at print time.
4. Faulty fuser. Normally the printer will report if the fuser is not reaching the correct temperature, but there are instances when this does not happen. Also it is possible for the fuser heat lamp to blacken partially, resulting in an area of the fuser that does not reach the correct temperature. This problem will affect an area of the page which consistently (same place, and all the way down the page) shows poor fusing. - Replace the fuser.
Print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
2600n faded print on both left and right side.(word doc, no images) not using color black print only.
Is the cartridge an original HP or an inexpensive compatible? The black cartridge could be out of toner. Not a common defect for the Q6000A cartridge though. If it is a poor quality compatible the defect may be the result of a misaligned internal component. Either way replacing the black cartridge should resolve the issue.
1helpful
2answers
Lexmark t520 suddenly prints poor quality, i.e. the previous page prints softly onto the next page and the right side of the page (2" from right) is streaked with toner. Please help. TIA, Mike
this sounds like you have a fuser problem look at the fuser and see if it has toner build up on the rollers ghost printing can be caused by the toner cartridge or the fuser. this would indicate that your fuser isnt maintaining enough heat for complete fusing. is you take the rear covers off and run your print job. look to the far left side of the fuser and you will see the heat lamp lit up. this light should cycle on every 1 1/2 pages or so. any longer than that and it wont keep up with the print job
Poor, faded print quality on left and right sides of paper
Have you check the teflon at the heater? have you clean the reflector of laser? Try that.
3helpful
Print fading down right hand side
I was able to fix it by taking off the top of the printer. This involved taking off 4 screws on the top of the printer. I then had to disconnect the wires going to the control panel by unhooking them from the right side. I then located a thin rectangular box which I'm assuming houses the laser. I removed this with 4 more screws and turned it over. There was a little metal flap that I moved back and below was the mirror the lasers shoot on before going onto the toner.
In the same spot where I was having fading, I noticed a lot of toner on the mirror, so I cleaned it of, put it back together, and the fading was gone.
This was after I tried a new toner and maintenance kit.
Hope this helps
Norman Weimar
Norman Weimar
k24674
