Hi!You can download the Britax Eclipse si from the following link--http://help.mothercare.com/resources/mothercare/products/Britax_Eclipse_SiThanks for using FixYa. Do rate this solution as FixYa.ThanksRylee
SOURCE: need to remove the cover
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
SOURCE: How do I remove the seat cover on a Britax Eclipse si?
You can download the manual and it should tell you how to remove the cover.
Blessings!
