I need installation instructions for a new hard drive
I have a brand new computer with no hard drive in it at all and I need to know how to install this new hard drive onto it
    Problem Solver:
  • 7 Answers
Here is the quick guide to installing the new sata HDD.
http://www.easeus.com/resource/install-sata-hard-drive.htm
Posted on Jun 09, 2009
Can I override the bios at startup so that it will recognize a new hard drive - for linux?
There should be no need to play around with your bios settings. Linux will install on a brand new hard drive as the sole operating system, or on an existing hard drive alongside Windows without any problem.
If you haven't already got a Linux distro, have a look at
http://www.ubuntu.com/download/desktop
Download whichever version of Ubuntu you prefer (LTS- the long term support version is recommended).
When the .iso file containing the operating system had downloaded, burn it onto a dvd, or install it on a usb drive.
Insert the dvd into the drive and restart or switch off/switch on the computer. The dvd will then kick in and offer you the choice of trying Ubuntu without installing, or a full install.
If you're using a new, empty hard drive just follow the on screen instructions and Ubuntu will install as the sole operating system.
If you already have Windows on your hard drive Ubuntu will give you the choice of either erasing Windows or installing Ubuntu alongside Windows. It's your choice.
Installing Ubuntu alongside Windows creates a dual boot hard drive. At start up you just choose which OS to use - Windows or Ubuntu. If creating this dual-boot system Ubuntu puts a (Linux) boot loader into the Windows OS so that Linux is recognised.
If you save the Ubuntu file to a usb drive you then have to change the bios settings so that your computer uses USB as the first boot device. Then restart your computer so that it boots in from your usb .. and Ubuntu will begin installing.
Whichever you use - dvd or usb - during the installation process Ubuntu will ask you how many GB of hard drive space it should use? You do not need to physically partition the hard drive. Linux will do it for you.
If it's a desktop PC you are using with Windows on the first hard drive and are fitting a second hard drive to install Linux on, or have installed Linux on the second hard drive .. and find that Linux doesn't appear at start up, it's because there's no Linux boot loader in Windows.
I quit using Windows many years ago.
Nov 01, 2015 | Everex IMPACT GC2500 PC Desktop
The sound disappeared on my computer after a new hard drive was installed. However the sound returned when I altered the green sound cable to a different socket at the rear of the tower. Within two days it...
if you installed a new hard drive.. did you also installed windows on that new hd? if you did.. you may need to also install the sound card drivers.
the sound from your speakers depend on the sound card on your computer, and the sound card works only if you install the drivers that are specific for that sound card/computer. if you need help finding the drivers post back you computer specs (model, brand etc) and operating system and we'll help you find the drivers that may need to be reinstalled.
Mar 26, 2010 | Microsoft Windows XP Home Edition
I have a Panasonic CF-72 Hdd crashed, just plugged in new Toshiba Hdd. How do I install Windows 2000. Have new CD disks
PREPARE HARD DRIVE
1. You would need to prepare the drive for installation of Windows (seeing that it is brand new)
2. It should have come with a CD, put the CD in the drive boot up and follow the process
If u tell me the Model of the Toshiba HD I can find instructions for preparing the drive for you.
INSTALL WINDOWS
- Once the Drive is prepared (meaning u have created a logical partition) THEN
- Put the Windows CD in the drive, boot the PC and follow the instructions:
Here's a Great Resource to help u with the installation: LabMice
ALSO
BootDisks (this should come in handy one day)
CAH
Mar 16, 2010 | Computers & Internet
New Hard drive
The two hard drive names will not make a difference and are compatible. Installing the new drive is not all that hard assuming you have all the programs and the OS. Using the back up OS will be your best bet. Just install the hard drive and then place the back up disc in the CD or DVD drive and boot up the computer. This will act as a temp OS system loading basic features allowing your system to recover from the disc. Just follow the on screen sinstructions and your on your way.
If given the choice make sure you select format the new drive the recover disc may do this for you automatically.
Let me know if I can help.
Joe
TIP: If the old drive is accessable picking up a SATA to USB connector will allow you to use the drive as a slave in your computer to recover some of your saved files stored on your old drive.
May 20, 2009 | Computers & Internet
Hard drive not found
Wayneard is correct. When you install a brand new hard drive as the ONLY hard drive in the computer, there is no operating system loaded. The computer will try to boot from the hard drive and stop. Switch your boot order to have the CD boot first, and be sure you have the operating system installation CD in your CD drive.
Also, double check your hard drive connections. Be sure it is in the "master" position on the hard drive cable. If there is a connection problem, the system will complain after CD start that there is no hard drive available to install the operating system on!
Good luck.
Dec 30, 2008 | IBM NetVista PC Desktop
No sonud after new hard drive installed
After installing a new hard drive you need to reinstall device drivers for sound and more peripherals.
If your computer is a laptop or a brand PC post make and model, for explample Dell optiplex 120.
If computer is assembled you will need to access the motherboard and post here the code number printed on the motherboard and on all device cards.
Sep 13, 2008 | Computers & Internet
My laptop has got a virus and I cannot get it fixed no matter what I tried. I want to reinstall the operating system, but I don't know where my Operating System Disk is. Is there any other way to reinstall...
what is the brand of your computer? some branded computers have an image inside the hard drive which you just need to access like in some dell computers. try checking out the manufacturer. try also looking inside your hard hard drive or click my computer.. if there are more than 1 drive inside and you just have 1 hard drive installed chances are the other drive could be the factory image of your system which you can try to restore
for proper image restoration try to contact the manufacturer of your computer
Jun 20, 2008 | Computers & Internet
Hard Drive detects immenent failure.
If this is a brand new hard drive from a store return it for a new one. Hard drives have a built in feature called SMART. For some reason the SMART function is reading that there is something very wrong with the drive. If you have more than one hard drive installed on the system make sure SMART is detecting it on the new drive and not the older ones by unplugging the other drives from the motherboard.
Aug 11, 2007 | Compaq Presario 5005 (470014-507) PC...
How to install a new seagate hard drive?
I have one thats ide ultra, & my computers see it as a disc drive, like a cd drive when i put it in an external seagate case. but when i put it in as an internal it shows up in cmos w/ 320 g space, & no matter which pin config i use it doesnt show when the os is booted. I enabled LBA like it says on the drive, & tried all the other options in CMOS & havent got it to go yet, but it sounds like its running perfectly when it powers up. it'll go, but its actin crazy. ill post it when i get that bastard.
May 02, 2007 | Seagate Barracuda 7200.8 300 GB Hard Drive
Computers & Internet Logo
280 people viewed this question
Ekse
Marvin
Marvin
