Nordic Track commercial 2150 when turned on the i fit screen starts up but then runs in loops, it will not boot up or allow access to any menus. The screen displays an I fit machine service message along the top it white. No buttons or programs work so maintenance screens are inaccessible. This happened after I tried to update I fit
Time to replace the Console board CPU, the Clock+power supply inside had been failed.
Treadmill Doctor
Blessing.
[email protected]
cell+whatsAPP:+50588611441
SOURCE: nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Step 1
Remove the screws or bolts securing the ends of the pedals
to the crank axles. Slide the ends of the pedals off the axles. Remove any
screws or bolts securing the left and right disc shields to the base unit. Pull
or pry the disc shields off the base unit and set them aside. Remove any screws or bolts securing the left and right side
shields to the base unit. Detach the side shields and set them aside. Examine
the interior of the base unit and locate the drive belt. Pull the drive belt free of the crank pulley, flywheel and
any other pulleys. Discard the old drive belt and install a new belt in its
place. Turn the crank axles by hand to confirm that the belt will turn smoothly
when the device is in use.
Step 2
Step 3
sincerely. Merry Christmas.ernesto cuadra
SOURCE: ifit console will not load keeps running in a loop?
try to RUN the software calibration, see your instr. manual how to enter and proceed for easy diagnose, troubleshooting, and fix it.
God bless you
