TP-LINK WR842ND From time to time I am not able to view certain webside. Here is an example for gmail pop3 serer: pinging from PC using domain server name ping -t pop.gmail.com Ping request could not find host pop.gmail.com. Please check the name and try again. piging from PC using IP ping -t 173.194.70.109 Pinging 173.194.70.109 with 32 bytes of data: Pinging from router using domain server name: Pinging pop.gmail.com [173.194.70.109] with 64 bytes of data: Reply from 173.194.70.109: bytes=64 time=33 TTL=49 seq=1 It is clear that sometime the DNS is not recognized. What could be the problem? It is a hardware issue?
Google has many different ip addresses. They have servers I guess you call them everywhere. I downloaded several apps that looked up IP addresses cause the ping had different ones I didn't use. They all led back to GooGle owning that address. Nothing to be alarmed about, theres just no escape from Google, they see everything, track everywhere, and won a lot of different IP
SOURCE: WLAN having consistant high latency with frequent all-out fail
I would suggest borrowing a different known working wireless adapter, and test trying that. Or test using a wired connection, just to prove it is the adapter. Perhaps the wireless adapter you are using is flaky.
SOURCE: connection to linksys wrt300-n router drops
Try to Disconnect and Connect the Internet Manually in the Wireless Network Connection. Also this can be a problem with our Computer or Laptops Lan Card which may be having issues in connecting.
