Just out of curiosity, are the batteries in the correct direction? When you half-press the shutter release button, does the meter needle in the viewfinder move?
I can't count the number of times I've put the batteries in the wrong direction on my own FE. I've never damaged the camera, and it works fine when I reverse the batteries.
Sounds like the camera is not getting battery current, since that is how it will act without batteries. Does the meter needle respond to changing light when switched on? If not, check battery polarity -- the + end touches the strip at the bottom of the battery compartment, the - end touches the battery cap. If that all checks out right, one of the wires connecting the battery compartment to the innards may be corroded or loose.
Set camera to M90 or B, it will free the shutter. If if fires at these settings but not others then you have an electronic problem. If it does not fire at M90 or B then you have a mechanical problem. Clean the battery cap with a hard eraser and make sure the batteries are in correctly - does the battery check work? Also check to make sure that the battery compartment is not broken. Using a thin round tool, insert it into the battery compartment and push down slightly (not Hard!) and see if the battery compartment gives or you see a crank. Also check for impact around the rewind knob. The FRE resister plate there is made of glass and impact breaks it.
hiwould you show the broken area? you can post picture the broken area if you have extra camera. there is one thing you should check battery door hook, post, and battery compartment area. please make sure what really broken then I can help
Mine has broken as well. It appears this clip is just to keep the battery from falling out as you open the battery door. It will function perfectly fine without the clip. Just be careful not to drop the battery when you open the battery compartment.
battery cover has small and minute parts so it breaks easily. getting a spare is difficult. only easy solution will be to take it to service center and fix it
you could but the cost and time would not be worth it,just find you some gray electrical tape,works wonders,but make sure you press down real firm while putting a good solid peace on ok. good luck hope i helped.
