SOURCE: casio fx-82ES scientific calculator
change the mode to stat and then start operating it in statistical mode
SOURCE: i can't find an antilog function in my calculator .
Anti log will be shown as 10^x (10 raised to power x) For natural log it's e^x I think it's shift > log
SOURCE: How do I graph an equation such as y= 5x + 2?
Turn calculator ON. If you do not see several icons press [MENu].
Use arrow to select the [GRAPH] application and press [EXE].
In the entry screen, the line with Y1= is highlighted. If it is not, use arrow to highlight it.
Press the right arrow, the highlighting disappears leaving you with Y1= and the blinking cursor.
At the position of the cursor enter 5 [X, theta,T] key under the [ALPHA]. On the screen appears 5X, complete you equation +2.
Press [EXE] to store function.
If you want to draw other functions, it is time to do so on that screen.
When done press [F6:Draw}.
If the screen does not show a lot of the function, you can use the arrow keys to pan the graph.
You can also press [SHIFT][V-Window] to set the window limits.
Hope it helps.
Testimonial: "Thank you so much!!!"
SOURCE: calculator statistics question, z score and std norm distribution
The Casio FX-115W/991W/115E/991ES have three functions P(, Q(, R( and t(: the last one calculates the normalized variable noted t.
The Sharp EL-520W ans several similar Sharps do it too. Here is a screen capture.
The
capture.
