You didn't specify if you're using DSL or cable.
I've run into this dozens of times. With DSL, keep in mind the software on the PC is what "dials out" to the ISP with your name / password, and you MUST set the name and password in the router. Otherwise, ONLY the computer that has the software installed (verizon, etc) will be able to connect.
If you're using a cable connection, you don't have to do this, however, most newer Linksys routers come with a 'setup' disk, which MUST be used regardless of connection type.
Also, make sure there is ONLY the LAN connection to the modem, NOT both the USB and LAN.
Wat is the model no of the router???
i hope u will use Wrt54g and make sure about the version no...
u need to upgrade firmware for ur router..
log in to www.linksysdata.com
enter the model no>>Wrt54g
u have to select the version no....
u can see firmware..download it and save it to ur computer....
open Internet Explorer...type in the address bar as 192.168.1.1
no username and the password will be admin(shuld be in lowercases)
linksys set up page will open....Click on Administration..below administration,in the blue bar u can see Firmware upgrade...
select the file which u have downloaded from the linksys website..upgrade it...reboot the router..it will be working fine...
if it is not working just post ur comments...
Is there any other way to access IP 192.168.1.1. ? I'm online but every time I search it says "cannot find server". Trying to fix my router.Thanks
I have the same problem. I'm using WRT54L with firmware of DD-WRT. When I have one computer connect via wireless and then the second computer is connected to the internet then the connection of the first computer is dropped. Could s.o. tell me if it's up to the configuration of depend on the ISP server configuration.
