SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
SOURCE: Sony Bravia KDL-46V3000
turm on the tv for at least 24 hours with rf signal it will automatically get ok.
SOURCE: My Sony BRAVIA KDL-46V3000 Television has messed
This also happened to me and may continue to get worse... If it goes away for a while after warming up, then it is the same problem... The LCD panel is probably going out, when that happens the cost to repair it is more than the tv is worth... If it is in warranty then you can have it replaced or fixed.
Testimonial: "You were so right. Thanks."
SOURCE: AT&T uverse remote code for Sony KDL-46V3000
hi! i have here a couple of codes for your SONY tv, just try them 1037, 1128, 1137, 1178, 1215, 1216, 1218, 1219, 1220, 1221, 1250, 1251, 1316, 1318, 1330, 1347, 1413, hope this helps!!!! goodluck!!!
