Compaq Presario 5000 PC Desktop Logo
Posted on Jun 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tools requirements for starting L3 Level Repair centre for HDD
Currently we are in repair industry i.e. L3 LCD panel repair supporting OEM's.We would like to start Hard drive repairs as well, pls share the requirements for repair Hard Drives of L3 level.
Caleb Judd
Level 2:
  • Expert 157 Answers
  • Posted on Jun 19, 2009
Caleb Judd
Expert
Level 2:
Answers
157
Questions
Helped
53650
Points
463
Repairing hard drives?? you cant repair surface problems on hard drives. you may be able to repair/replace the circuit board which controls the hard drive but this is a fairly uncommon problem. For data recovery off damaged hard drives you need a very expensive clean room and very very expensive tools.
2answers
WHO IS THE BEST IC FOR THIS TV AND HOW MANY COST WILL BB PAID
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Abctay com China Wholesale Wholesale Electronics Gadgets tv parts power...
1helpful
2answers
Samsung led tv ua40F6400 power board
If you wish to buy a new power board, contact the authorized service centre for Samsung.
3answers
Dead pixel
your stuck with the dead pixel unfortunately unless you install a new lcd but its not really worth doing on an older machine
2answers
I have a sharp 42" lcd hdtv & the right half of the scren is black but i can still see some green highlights. any suggestions?
This tv the LCD screen panel it shorted and dead.This tv can't be repair,only replaced the LCD screen panel.Not,worth replacing the LCD screen panel,because LCD screen panels are limited produced by the tvs industries and will cost same as a new tv,if the LCD screen panel require replacing.Sorry the tv now,only worth as a salvage tv electronic boards for parts only now.
4helpful
I need to do a low level format for my hard disk. Bad sector problem. Do you guys have any application for that particular kind of formatting?
Bad sector on hardisk there two kinds of that is software and physical. physical badsector caused from plate of hardisk damage is caused by dirt, fallen down, collided, to be incised, etc. While software badsector can be caused when hardisk busy sudden die, cause of usually broken electrics current.
For the bad sector damage of physical of hardisk, we require a really of expert to repair the hardisk. While damage of software we can repair xself use software or tool. One of the software which can be used to repair bad sector on hardisk that is HDD Low Level Format Tool.
Using this software hardisk can be low level format. Require to be paid attention that using low level format on a hardisk, causing all data in hardisk will lose and cannot be recovery again. But this way will be more effective eliminate sector bad.
HDD Low Level Format Tool Support Hardisk SATA, ATA or SCSI, can is also used on removable media like flashcard, flasdisk and etc. To run this software is very easy, that is :
  • Download HDD Low Level Format Tool from the link above and install it till finish.
  • Run HDD Low Level Format tools
  • Select a hardisk which will repair then click continue.
Select LOW-LEVEL-FORMAT tab", if you sure To format the hardisk click "format this device" button and await till finish. ad for hardisk repaired hence required time will longer.
HDD LOW format level can be download from following link,
http://hddguru.com
note : If on hardisk have detected badsector, before doing above steps, first step to backup all existing important datases
Premium experts are not paid for free questions so require your appreciation in form of a 4 thumbs rating
THANKS
The LCD has gone to digital noise only. Can it be
Short answer is yes. I recently had a screen replaced on a HG10 HDD HD camcorder in the UK for about £100. You first point of call should be a Canon authorised repair centre for your country. Alternatively look on line for a camera repair centre on google.
Please do NOT accept this invitation for paid tech support until you read this entire script as I am myself rated as a Wiz on Fixya and require specialized tech support for the below unit currently in our...
Does the led on the sc board light? D6583. According to Panasonic the 7 blink error is a driver sos2 this could be on the su, sd, or sc boards. Panasonic doesn't give much help on this set, sorry.
My name is Katie Dear, I am a service technition for Basic Your Best Buy, INC in Monroe, LA. We are factory authorized for panasonic, Sony, Toshiba, Mitsubishi, Samsung, Sharp,RCA, if I can help you with any of these sets I will be glad to my email is [email protected].
Black band across screen
throw away the LCD it's not repairable unless you work for an LCD repair center. Sell the backlight unit on ebay to get some money back into your pocket.
The film that connect from the PCB board to the LCD is either not bonding correctly. This can only be fixed by an industrial machine.
It requires heat to press against the film to bond it to the surface.
2answers
RCA 32 in TV no picture no sound just a beeping noise TV power is on
the tv has one part of the power supply working this is needed to have the microcontroller ready to work. But the tv needs more than that for work im talking 'bout the high voltage power supply who is now damaged. the parts required depends on the diagnosis in the bench but at least two are needed. the cost of this repair of course depends in how many parts are going to be replaced, but i concider this repair kind of average in this technology.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
