I have put the HD into another PC and it does boot from there. Since no video my assumptions is the MB. I have also swapped the PS (same model) with another PC and that is good as well. I do see lights on the MB but don't know what they mean. Can't seem to find the manual online yet.
SOURCE: Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
SOURCE: Can not get the MB to power up. The PS seems to
to boot you will require
mother board
graphics of some kind
cpu
ram
psu
if nothing at all happens and there are no lights you should probably make the psu the first thing to test/replace
