TRY TO SEND FAX ERROR REPORT 345 TROUBLESHOOT SAYS NO COMPUTER CONNECTION
SOURCE: FAx Error
I understand that you are receiving the error "fax not sent" and the transaction report Error 389*. while sending fax.
The issue that you are experiencing is due to communication, however please follow the instructions from the below article to get the issue resolved.
Here is the web document:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=buu02549
Just copy and paste the entire link into the Internet browser's address bar and press enter.
This should resolve the issue that you are experiencing with.
Regards,
Lawrence
SOURCE: fax not working Error 388
We had the exact same problem. Static on the line. We had the cable company check and sure enough our digital modem for the phone line was bad. The new replacement fixed the problem instantly.
SOURCE: Problem faxing-error message
Error 388:
Definition
There is too much noise on the line
for a valid connection between two fax machines to complete. The noise
problem might go away over time.
Solution
Retry
the fax reception at a different time when telephone line conditions
have improved. Call the telephone provider if line conditions fail to
improve.
Error 403:
Definition
During a V.34 transmission, the
local machine is unable to connect (handshake) with the remote machine
and is consequently unable to send a T30 frame. This occurs when the
line is disconnected or if line conditions degrade during the session.
Solutions
SOURCE: We have a HP colour laser jet CM2320nf MFP and
Check phone line. use a normal phone and plug into the same phone wall socket that the MFP is using, do we have a dial tone? Do we have a noisy line, any buzz or crackel will cause issues
If there is no dial tone ring line supplier, If it is noisy line do the same
Also check phone line is plug into "line" socket in the back of machine not "ext'
Also check no prefix is required to dial out, unit needs its own phone line..
Also try using resolution of fax as standard not fine, this requires less info to go threw the line
In Australia we have a thing called folds (fax online diag service), basicly it is a fax number you ring and the phone company who own the line send back a report, most times the issue is noisy line or no line available
hope this helps
Cheers
Soulvisitor
SOURCE: I get *388 error sending faxes from hp officejet v40 over VOIP
Please check this:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=uk&docname=buu02549#Error386
Here you will se a lot explinations from hp
If you need more help come back.Post /
thumbs / testimonial are
welcome!
