How do I get rid of the yellow tint on the display screen?
SOURCE: Sony HDR-HC3 LCD touchscreen blacked-out.
I have the same problem, screen went red then about a month later went black. If I rotate the screen so its on the outside when flat against the camcorder side, it works OK so I'm living with that for now, but you can't use the corder in the normal way for recording viewing the screen. All other functions are OK.
I have the problem, but not the solution.
Rob
SOURCE: sony hdr-cx7 image jitters when the cam gets hot
one fix is turning off steadyshot then try putting the camcorder upright(the lens pointing up) for few second until you see the video stabilize, then use as normal but the camcorder will jitter again if handle it roughly. This is just a workaround, i still dont know why it happens, need to send it for repair soon.
SOURCE: have E:61:10 flashing up on screen. cannot find it
error code alerts user for malfunctions detected by the camera. the error E:61:10 would pertain to the zoom mechanism malfunction. issue may be with with lens block zoom MR sensor or zoom motor drive circuit. 1st step troubleshooting steps would be to reset camcorder (check manual for reset button location) and power reset (remove battery and leave camcorder w/o any power source for a minute). if still the same then service would be required. hope this info helps. thanks.
SOURCE: Hi i have a Sony hdr CX550 handycam camcorder
Most mics will work if the plug fits the socket on camera and it fits on the hot shoe okay, I never use Sony mics on my Sony camera, you end up paying for the name, not the item.
SOURCE: No picture shows up on
If the issue persists even after performing allthe above-mentioned steps, service is required.
