Apple iPod touch Logo
A
Anonymous Posted on Feb 27, 2018
My parents restricted my ipod for personal reasons, but now they have un-restricted it but my wifi will not connect. My parents were going to give me the password for the wifi but my ipod will not even hit on the wifi to let me connect it says unable to conncect
savannah janiszewski
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 27, 2018
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
63
Points
What you need to do is completely reset your ipod. Back it up to a computer or hard drive and download iTunes. From there, you'll need to factory reset it. Or you can try shutting it off and just simply turning it back on. Goodluck!
4 Related Answers
Anonymous
  • Posted on Mar 20, 2009
SOURCE: unable to connect to wifi network on ipod 2g touch
i Can't connect my ipod to my wifi wich has a netgear router
Anonymous
  • 2923 Answers
  • Posted on Jul 01, 2009
SOURCE: ipod touch won't connect to wifi
There's a possibility that the password that the network was asking is the 'network key' (e.g. WEP or WPA-PSK). If this is the password that the network is asking for, you need to contact the administrator of that network and ask for the Network Key, because that network is secured. They put this kind of security to prevent unauthorized users to connect to their wireless network.
Have a great day!
Anonymous
  • Posted on Jul 15, 2009
SOURCE: I have the same problem. My ipod is frozen on
this not for the itouch? try holding circle then menu
Anonymous
  • Posted on Feb 17, 2010
SOURCE: wifi works well on laptop but not on ipod
I know that ipod has a weaker wifi detector than laptop
1helpful
Ipod touch wifi password
Yes! It will be whatever the bill payer of the wifi you want to connect to has put on for security reasons!
So, I put in a game : MW3 and go multiplayer, but it says that it is disabled because of parental control restrictions.I've turned everything off, please help. I am on a 50gb internet plan each mo
It's not the internet settings, it's parental resctriction ;)
I don't have a PS3, but I guess it could be found in some account management, or something like that.Then you have to find Parental Restriction.
The reason this have occoured, I guess, is because you have registered the psn-account on a e-mail adress where your "age" are under 18 years. You probably will need a password for your parents e-mail adress.
My xbox 360 mutes everyone for no reason and i cant un mute them
This is due to parental restrictions on your xbox 360. I would find whoever controls these and ask them to change the setting to allow you to communicate with other. These parental controls may be in place because you are too young. Good luck!
IPod touch Wifi problem. I got a new iPod touch 4g and my dad got new pocket wifi so I tried to connect my iPod to the internet and it would work for about five minutes but then it would disconnect...
hi this sounds like the pocket wifi firewall or push is stopping you from connecting, it will show connection when the password is put in correctly, but unless your either ip, or mac address is registered with the unit it will not let you connect to the net, you will have to see if there is a start ip and an end ip address in the wifi unit, as this might have restrictions to ip address numbers..for example..wifi ip start address might be 192.168.0.1 and wifi end address might be 192.168.0.4 where as your ipod might have an ip address of 192.168.0.7 ( just an example ) so even though the password is ok, it will let you connect for that few seconds, as it has verified the password and is correct, but the ip handling has not allowed you access and the firewall then steps in and blocks you.... hope this helps
DOES THE IPOD APPLE 8 GB BEED TO BE HOOKED UP TO A ROUTER
If by hook up, you mean wired. NO! You can connect it wirelessly, it's a WiFi ready device. All you need to do is to go to Settings> WiFi>
.. Turn ON WiFi and select from available networks around you.
Normally, WiFi signals are protected by a password. You need to know the correct password first before you can connect to that WiFi network.
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: [email protected]
3helpful
I just bought an ipod touch and I thought it was already set up for internet. How do I do that?
No, iPod touch have no way of connecting to the internet other than wifi (unlike iPhone that has 3G).
This means that there must be wifi signal around you before you can browse the web or receive email.
To check for available networks around you, on your iPod touch, go to Settings > Wi-Fi, then select the network that you want to use.
Often times, wifi networks are secured by a password, meaning, you need to ask permission to the owner of that signal to gain access. In a cefe for example, you can gain access to their secured network by simply asking the person in the counter.
For more iPod touch / iPhone tips, click here.
My 32G iPod Touch won't stay connected to my Home WIFI
go to settings,general,wifi, turn on wifi
if that didnt work go to the apple retail store and theyll help you for sure
if not they cheack the warrenty and give you a new one
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
