A few things to check, first off is adequate water supply(obviously).. next check your drain system, if your unit gravity drains look for a blockage, but if you have a secondary drain pump to pump away water check for proper operation, if that pump fails the machine will no longer let water in( thinks it full and no need to produce more ice if it cant get rid of old water
Thanks for your help - will pass it onto our electrician when he comes to see if any of these are the problem.
Cheers! Penny Hewitt & Andy Smith
ice maker is not connected and there is water frozen on bottom of flloor of freezer and leaking
