Investigate these areas if your dryer is not starting:
Proper Voltage from the House
Your dryer may not be receiving adequate voltage to start. Make
sure your dryer is plugged in. Also, check the circuit breaker panel to
make sure all the circuit breakers are in the correct positions. Or
check to make sure no fuses in the fuse panel are blown. Try plugging
something else into the same outlet. If it won't work either, then there
is likely something wrong with the power outlet. Any of these could be
the reason power is not getting to your dryer. Also, refrain from using
an extension cord to plug your dryer in.
Door Switch
If your dryer's door switch is defective, it will not
allow your dryer to start. Test your dryer's door switch. If it is
defective, replace it.
A dryer cannot start if its start switch is
defective. Test your dryer's start switch. If it is defective, you will
have to replace it for your dryer to start again.
A thermal fuse is a heat-sensitive fuse attached to
your dryer's exhaust duct (in most models) that is designed to blow if
the dryer overheats. A blown fuse would cause your dryer to not heat, or
to not work at all. Open up your dryer's cabinet and locate its thermal
fuse. Test the component. If it has blown, replace it.
A defective dryer thermostat could be what is
preventing your dryer from starting. Open up your dryer's cabinet. Test
each of your dryer's thermostats. Replace any that have become
defective.
Your dryer's timer will not function properly if its
motor is malfunctioning. Open up your dryer's cabinet and locate its
motor. Test the component. If it is not functioning as it should,
replace either the motor itself, or the entire timer assembly.
A burned out motor could be what is keeping your
dryer from starting. Test your dryer's motor and if it is defective,
replace it. You will have to open your dryer in order to gain access to
its motor.
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is
not being supplied with the proper voltage. Here are three ways to make
sure power is getting to your dryer: First, make sure your dryer is
plugged in. Next, check the circuit breaker panel to make sure all the
circuit breakers are in the correct positions. Finally, check to make
sure no fuses in your fuse panel are blown. Any of these could explain
why power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because
its heating element is defective. Heating elements are irrepairable. If
yours has ceased to function properly, you will have to replace it. Open
your dryer's cabinet and locate the heating element so that you can
test it.
Another possible cause for a dryer not heating up
could be attributed to a faulty thermal fuse. Once a dryer's thermal
fuse has blown, it is no longer of any use. If your dryer's fuse is
blown, you will have to replace it. Open up your dryer's cabinet and
locate its thermal fuse so that you can test it.
If any of your dryer's thermostats have become
defective, they could be the reason that your dryer is not heating. Open
up your dryer's cabinet and test each of your dryer's thermostats. If
any are faulty, replace them.
A defective timer motor could also cause your dryer
to not heat up. Test your dryer's timer motor. If it is no longer
functioning as it should, replace either the entire motor assembly, or
just its motor.
Good Afternoon lah7106, thank you for your post! I understand you are seeking information on how to test your Frigidaire dryer. However, what exactly is the issue your dryer is experiencing? Is it not heating or drying? Maybe the problem you are having is something I can help troubleshoot. With this information I can better address the issue at hand. Thank you!
