How do i find the age of my uniden bearcat bc60xlt-1 scanner
SOURCE: How do I Program my Uniden Bearcat BC60XLT
i am having trouble programing frequencies into my scanner i need help!!!!!!!!!!!!!!!!!!!
Here's the link for your manual It's 3.71mb http://www.uniden.com/pdf/BC60XLT-1om.pdf . The manual is written for "People" not "engineers" If you still have problems, post a reply and I can help further. Hope this helps
SOURCE: i got my scanner and it didnt come with a book and
Here is the link to download the pdf manual for the BC60XLT. http://www.uniden.com/pdf/BC60XLTom.pdf
SOURCE: Need user manual for Uniden radio/scanner BC60xlt-1.
Follow the link below to download/print the manual for your scanner. You may or may not be able to hear the services you mentioned using this scanner due to its limited frequency coverage. Many public service agencies now transmit in the 800MHz range, and many have upgraded to trunked and even digital radio systems. I cannot find any reference to PCH LOCK, but an educated guess would be that it means all programmed channels are locked out. If none of the 10 channels contain programmed frequencies, displays will show 000.0000MHz, and all channels will be locked out. Programming a frequency into any channel should override the lockout. On the other hand, the message could indicate that this old scanner is tired and in need of replacement. Here's the link to your manual:
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
SOURCE: uniden bearcat bc60xlt-1 channels wont unlock
Channels have to be programmed with a frequency before the scanner will allow them to be unlocked. The L/O indicator should automatically turn off once a frequency is in memory.
