Need a decrypt code?
You can use the same as that for the 7050 model. You NEED to use the remote control, press setup and then ffwd, frwd, fwd, rwd in sequence, it will appear a number. Press the right arrow key until it reaches 255 (it is fast, it jumps from 001 to 255), to get out, press set up again. You know can read all regions. In fact this is the same fix for the 7050 model.
