What is the correct replacement Halogen Bulb for underneath the Advantium? Is there any brand other than the 1 that GE appliance parts dept. sells that may be less pricey? Thanks
SOURCE: replace inside bulb
There is a step-by-step guide with photos here.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Advantium Bulb replacement
You are describing the little bulb in the front. The speedcook light is a different bulb
See: http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
SOURCE: i need to replac the bulb in my ge advantium. what kind of bulb
Hello. Use a 35 watt halogen bulb with a GY8.6 base. Lowe's part number 15797.
Regards, --W/D--
SOURCE: GE Advantium SCA 1000 top rear cooking bulb blown
Hi
Thanks for using FixYa. First
please disconnect the power of the main fuse or circuit breaker panel and
remove the screw from the side of the light compartment cover and lower the
cover until it stops. Now gently pull the bulb from the receptacle. Raise the
light cover and replace the screw and then connect the oven with the mains and
switch it on.
Please do accept the solution if
the issue is resolved or else revert for further assistance.
Thanks
Rylee
