The ice maker is time filled, it only has a certain time in which to fill. There is no way to adjust the water level. Check the pressure limiting valve which is in the water line before the filter. Have you replaced the filter? Remove the filter and pressure limiting valve and see if the ice maker receives more water. If it does, then replace the filter and check again. If it is still good, the pressure limiting valve is faulty.
water supply is good, temp is cold enough, ice in tray but will not come out
crashed ice ,and cube ice and water kept switcing by itself
I have my ice maker on cubed but it gives me both cubed and crush at the same time and it takes forever to fill my glass
ice maker is producing ice but it is large ice cubes and stuck together
