SOURCE: 320GB WD passport essential works with XP os but not with vista
both of my vista machines worked perfectly... i am not using the software that came on the drive. as a mass storage device it works perfectly.
SOURCE: ibm t43, xp pro won't recognize my WD 320 passport
Well, that IBM is from 2004, the usb port and drivers is to old for the WD 320 who requries USB 2.0. Thats why your IBM dosent recognize it, your IBM getting wrong signal from the WD thrue the old usb port.
I dont think you gona make those items to work properly togher M8, sorry
Nic
SOURCE: WD My Passport Essential 250GB USB2.0 is not working in WIn 98SE
Try using a Usb 2 cable "The one that came with the WD My Passport " And put it directly to the PC...
In some cases, Like mine, I used an extended cable + the cable that came with the "WD My Passport" and i got the same problem ..
So i simply removed the extended cable and put the put "WD My Passport " directly to the PC with its own cable and the problem was solved to me ..
Samer.F
SOURCE: WD 500 GB Passport Formatting error
you may have a FAT32/NTFS format problem between your wd500 and your pc. or differently formatted partitions. right click on their device letters on 'my computer' and look at 'properties'. should tell you how they're formatted and # of partitions, etc.
just a guess!
good luck!
SOURCE: How to format WD Passport 1TB to FAT32
Plug the drive into your PC.
Right Click on My Computer (or Computer in Vista/Windows 7) and select Manage.
Click on Disk Management.
Right Click the Volume in question and select Format. Select FAT32 in the options.
