Dryer wont heat up
SOURCE: kenmore gas dryer wont heat, model #11074832400
check the igniter,thermal fuse,operating themastat there is a small plastic piece on the lower left hand corner pop that out and when you turn your dryer on it should be glowing red if not its the igniter
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
SOURCE: kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
SOURCE: KENMORE DRYER MODEL NUMBER 66912690 WONT HEAT
Check the voltage at the terminal block where the cord hooks up for 220 volts.
Remove the rear panel and check the thermal fuse located on the upper portion of the heat canister.
Check the Hi-limit thermostat on the bottom portion of the heat canister.
Check all the wires for a burned or loose wire.
Check continuity of the heating element.
SOURCE: Kenmore gas dryer model #76812690 will not heat.
does the dryer heat initially when you first turn on the dryer Or no heat at all?
the first thing i would check is tthe thermal fuse thats located on the back of the unit. test it with a multimeter and see if it has continuity, if it doesnt then replace that and your operating thermostat. the check to be sure you venting to the outside of your house is not clogged
