Question about Apple MacBook Pro Notebook
Gray screen on macbook pro
When booted, computer starts and fan is running high. only gives gray screen
    Sergeant:
    Champion:
  • Apple Expert
  • 396 Answers
Does it chime?
could be ok if it chimes.
could be bad ram, bad hdd, spill damage, liquid damage, might need new logic board. Places on ebay offer repairs for flat rate for about 250 bucks.
Posted on Jul 25, 2014
6ya staff
SOURCE:
Anonymous
  • 28 Answers
SOURCE: completely white/gray screen
First try this: shut it down, disconnect the power cord, pull out the battery, then hold the power button for a full 10 seconds. Reinstall the battery, reattach the power cord, turn it back on.
Still doing it? Put the reboot disk that your Mac came with, or the disk to the version of Mac OS X that you're running.
To start from disk hold "C" as your Mac is first turning on from a complete shutdown.
Dan Crowley, iKnowApple.com 919.280.3101
Posted on Nov 09, 2008
Anonymous
your hard drive has most likely crashed.  this happened to my buddies macbook and it was $300 for a new hard drive, hopefully you still have a warranty on your mac, that way apple will cover the price.  take it in to apple and have them diagnose the problem.  my buddy was lucky bc apple covered the cost, if they refuse just be pushy and theyll eventually do it for you, im sorry
Posted on Nov 25, 2008
Anonymous
  • 121 Answers
SOURCE: My Macbook Pro wont boot - stays on the blue screen
The fact that the "BONG" sound (or better known as the MAC CHIME) does come on and nothing further means that the computer cannot find your hard drive or (sometimes worse) cannot find the operating system. This means that you will have to remove the hard drive... then insert it nice and firmly again. Try now to boot. If nothing happens then your drive has gone faulty and it could mean that you may have lost your data... NOT NECESSARILY though.... What I mean by that is that you may still be able to access the dat when you connect the "faulty" drive to another computer via USB with an external casing and then get your DATA off it.
Posted on Jul 06, 2009
Tim Digibrain
  • 846 Answers
SOURCE: on booting up my macbook pro I get a lot of
Do the patterns of distortion change as you are twisting and bending the laptop body? If so, you're dealing with a logic board issue. Probably your GPU is not soldered properly anymore. Go to the Genius bar first, if they can't help you can try a self repair or send it to a third party place. There is a free Macbook Air Repair guide that will show you how to do it. iPad Repair
Posted on Jan 29, 2010
Anonymous
  • 20 Answers
SOURCE: MacBook won't start up.
If you have your Mac OS X Install disc, insert it into the drive.
Restart the computer and hold down "C" while booting.
Choose your language.
Select "Disk Utility" from the "Utilities" in the menu bar.
Select your Macbook's hard drive in the left sidebar.
Click the "First Aid" tab thats along the top of the viewer window.
Click "Verify Disk" (not verify disk permissions)
If this shows errors click "Repair Disk"
Once completed close the Disk Utility window.
Restart the computer.
If this fails to fix it as well then your next option would most likely be recovering your files from the macbook either by booting into target disk mode (hold down T at startup) and transferring them via a firewire cable, or removing the hard drive and hooking it up to another Mac to get the files. Then do a clean install of Mac OS X using your installation discs.
Posted on Feb 15, 2010
Locked
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Feb 23, 2014 | Apple Air Computers & Internet
Macbook stuck on load up screen
When you say "load up screen", I assume you mean the Apple boot screen (it has the apple on a gray background).
You might try resetting the PRAM on the macbook.
You can do this by pressing and holding the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
So, turn the macbook completely off. Turn it on and immediately press and hold the Command-Option-P-R keys until the computer reboots and chimes. Once it chimes, release the keys. Your system should boot normally.
Jan 19, 2014 | Apple MacBook Pro Laptop Computer with...
Macbook pro dark screen
Close the lid, attach an external monitor, reopen lid.
Your display should now show on that monitr. If it is, your display on the MacBook Pro may be bad. I would try resetting the PRAM and the SMC before going to an Apple store. The SMC controls the MacBook's power founcts (see below)
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jan 12, 2014 | Apple Computers & Internet
Fan won't stop
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jul 27, 2012 | Apple MacBook Air Mac Notebook
When booting up my laptop it has a gray screen with the apple for a minute and then it turns to a circle with a slash through it
Boot from the CD/DVD that came with your Macbook. Launch 'Disk Utility' and perform 'Repair Disk' as well as 'Repair Disk Permissions' on your boot drive and hopefully that will fix the issue.
If that doesn't do it, try holding the Option key during startup to select the boot disk and select your Mac HD. If it boots in this manner there are rumors about some bad SuperDrives out there causing this boot issue. So you may want to boot it while holding "D" and run the Apple Hardware Test from the DVD/CD.
Mar 19, 2010 | Apple MacBook Pro Laptop Computer with...
Macbook Pro goes from gray apple screen to black
Try booting into single user mode by pressing Command+S while booting. You should then be at a prompt. Type in:
fsck -f
and press Return. Let it run and see if it corrects any filesystem issues, then reboot when it's done.
Apr 25, 2009 | Apple MacBook Pro PC Notebook
Wont turn on
Start the computer and hold down the "C" key when you hear the start up chime. Keep holding down the key until the computer boots into the OS installer. You are going to have to reinstall the OS. Just follow the instructions from there.
Jun 25, 2008 | Apple MacBook Pro Notebook
When turning on my macbook pro
Does it work with an external?
1) If it does boot through external. Your LCD, LCD inverter, or LCD cable may need replacement.
2) If it does not boot, then it may be problems with video card or motherboard problem. May need motherboard replacement.
Please let me know the follow ups of it. Thanks!
Mar 03, 2008 | Apple MacBook Pro Laptop Computer with...
Open Questions:
See all Apple MacBook Pro Notebook Questions
Apple MacBook Pro Notebook Logo
96 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
