No response when pool heater buton pushed on pad. Service lite comes on and E01. Replaced thermistor and still get this code. Any thoughts on what might cause a E01 fault if not thermistor? I also tested thermistor to be sure new part wasn't totally open ... got a resistance reading so should be ok. Thanks!
Mike
SOURCE: Sta-Rite SR400 heater displays error E01 and doesn't fire.
Resolved - the thermister was bad.
SOURCE: E01 fault and service light on
If you are still seeing the EO1 error code, turn over the display panel and see if there is a RED light next to a set of letters. Whatever the light is next to, that would be the cause of the error code.
SOURCE: sta rite heater won't start
TURN THE BREAKERS OFF FO R 20 SEC IF PROBLEMS PERSIST SEE CODE A POST
SOURCE: Sta-rite pool heater shuts down as soon as the
Between the two water pipes on the left side of the manifold is a two inch plug. When you take this plug out the thermal regulator assembly will come with it.It consists of "O" rings, a spring and what looks like a thermostat in a car. This is the probal bad part although it could be the spring also. You can get these parts seperatly or in a kit. If this is an older heater the kit is the way to go so you get all the nessary "O" rings and you will be covered on everything you need.
SOURCE: Ref: Sta-Rite Max-E 400. Pool temp is about 75
Your temp sensor has gone bad and will need to be replaced. It's a small tube that slides into the water manifold and you can follow the wires back to the board. Just unplug and set a new one in place.
