I cant write or paste anything in my sandisk 16gb memory stick
This Solution to remove Write Protection from USB Pen Drive might help
10.April.2014
SOURCE: problem with launchpad sandisk cruzer micro 16Gb mem stick (u3)
Start at the beginning. Look at how you entered your password and retrace your steps.
SOURCE: I have a Cruzer Sandisk memory that worked before,but not anymore
Ithink the disk is damaged, you should contact sandisk local service center to see if the warranty of your disk is not void. you can use the following link to locate the service center.
http://www.sandisk.com/sandisk-support/contact-us.aspx
SOURCE: tried it on 3 computers and they can't
Then that stick has died, junk it. USB sticks wore out every time you use them, that one has probably reached its end of life.Next time make sure that you have a backup if you store sensitive data on one of them.
SOURCE: i cant format or put
Some Verbatims have a write protection switch on its side - make sure it's not activated. Then open the properties of the stick in My Computer. If in there the stick isn't set as read only then it has died - there's nothing more you can do to save it. Junk it and get a new one.
Information you need, you can download here
SanDisk Cruzer Edge 8GB 16GB 32GB 64GB Capacities
open windows explorer navigate to your memory stick then go to the information you want to back up select the information right click?select copy then back to memory stick select then right click?select??paste
or select the imformation hold the cursor on then drag it to the memory stick and drop it into it
or?select the imformation right?click and send to the memory stick
ERROR CODE 0x80070545D
