Have you cleaned the small, narrow glass window leftmost of the platen? It is directly above the scanning bar's "home" position, and that's where the document is scanned, while it's fed by the feeder, passing over the bar (the paper moves, as oposed to platen scanning, when the bar is moving and document remains still).
When you installed the button manager you should be able to go in and change the SC descriptions ex. SC1, SC2 - SC6. When you use the sharp desk to scan you are operating in a pull scan but when you use the SC programs you are using the push scan mode. You can change the SC mode when you put the copier into scan mode.
If subcode is 00 then network connection is problem, if 02, then its not talking to the network scanner tool on the computer. Might be an IP address problem, where the address in the webpage of copier is wrong for the PC.
Found a very good solution...Use Adobe Acrobat to do the scanning. Launch Adobe Acrobat and select the AR-M205 as your scanner and proced from there. Adobe will pull up the Sharpe software to do the actual scanning but Adobe will be in charge and create a pdf file. I am using Adobe 6.0 which is not one of the free versions, I think.
check your settings on tray one. make sure the you set it to 11x17 by the way what is the model of your machine? don't set the machine to auto detect paper.
